07-08-2023 01:28 PM - last edited on 07-08-2023 07:18 PM by Dunkman
07-08-2023 02:18 PM
Make sure the phone connects to T-MOBILE
If the phone is not connecting to T-Mobile, change the Network Connection from Automatic to Manual and select T-Mobile
If your issue is with data, make sure your Roaming Mobile data is enabled and your have disabled your mobile data limter
07-08-2023 01:42 PM
You will need to go to your Settings>Cellular>Network Selection and set it to T-Mobile on an iPhone.
07-08-2023 01:31 PM
It's only T-Mobile so the coverage is up to them. We know Alaska doesn't work. There seems to be some question in NYC. Do you know if your phone has been enabled for volte yet? Data and text should be fine. Talk is the variable.
