U.S.A. 15 day top up
Blackie2
Is the 15 day U.S.A. talk and text $15+ TX give you 15 days usage
Chalupa_Batman
What @dust2dust and @JRod said.  If possible, I would do it either the night before or a few hours before you go in case you run into any issues, you're able to come to the forum here and ask for assistance. We'll direct you how to reach a customer service agent.
Blackie2
Thanks
JRod
@Blackie2
It will give you 15 days starting from when you add it to the account.
dust2dust
Yes. From the moment you buy it until the counter switches to 0/15 which should be 360 hours later.
