Payment
Baba6
Need to remove my credit card on my account
9 REPLIES 9
@Baba6
If you are porting out to Virgin Plus, your account will be closed, SIM will rendered useless and all account information will be cancelled. This will include your CC information.
But if you still want to confirm, you can private message them at:
@Baba6
use that link supplied by @LitlLdy and you can message a Customer Support person to remove the cc from your account. Give them as much account info as you can ie: account number, PM pin number, email address, last payment date etc. If you plan on porting your current number to Virgin, remember to keep your PM account active untill successfully ported at which time the account is closed automatically.
@Baba6 wrote:
how long before someone assists me to remove my credit card completely and not replace
@Baba6 , I gave you the link to send a private message to a Customer Support Agent (CS_Agent) so that you can ask one to remove your credit card from your account for you. You'll typically receive a response back within 30 minutes, during peak times, expect a maximum wait time of 48 hours.
Edit: If you decide to port your Public Mobile phone # to Virgin Mobile your Public Mobile account will permanently close right away. If you don’t it will take 90 days of non payment for your Public Mobile account to permanently close!
Baba6
Baba6
no i want out completely changed to virgin mobile
LitlLdy
@Baba6 , Please send a private message to a CS_Agent to have it removed for you.
You can send a private message to a CS_Agent using the link below: ->   https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Customer Support Agents are available from:
  • Monday to Sunday: 9 AM to 10 PM EST
A CS_Agent will respond back in your Community mailbox at the top right of this page (envelope icon to the left of your community avatar).
JRod
On your account, if you go to payments, click manage subscription, it will then show you the current payment method on file and allow you to make any changes.
dust2dust
Only support can remove it. You could change it if you like. You can turn off the autopay. I guess you're intending to port out.
