Trying to activate my sim and I get this, and it trys to text my sim, which is not working
01-14-2024 07:03 PM - last edited on 01-15-2024 09:29 AM by computergeek541
My Account
01-14-2024 09:16 PM
Put in your old sim card and you'll get the text there on your old account. Once it's set up you can put in your new sim.
01-14-2024 07:22 PM
@Darrly9876 Do you see option for “didn’t get code “ tap it it may give you option to send code to email instead . If still no luck get support to help you gain access
send a private message To CS_Agents
01-14-2024 07:17 PM - edited 01-14-2024 07:17 PM
Hey @Darrly9876
Try this.
Can’t get the 6 digit 2FA code to your phone?
First, sign into your account at www.publicmobile.ca and use the email you signed up with and the password. If it asks you for a 6 digit code, it will say at the top left CONFIRM YOUR IDENTITY.- Enter the 6- digit code sent to *********. But it’s not working!!! As you see by the screenshot below, 1. Click the This is a trusted device. 2. Didn’t get the code? Click on that.
Then, the next window that pops up is this.
Click on Send email. Here it will send you the 6 digit code to the email you registered with. This step is very important. Do not just copy and paste. Enter each digit using your keypad.
You should now be able to get into your account.
Then once you're all set up, your it can go to your phone afterwards
Created by Chalupa Batman
01-14-2024 07:15 PM - edited 01-14-2024 07:18 PM
If there isn't an option which reads, "didn't get the code?" which gives an email option to receive it, get ahold of the customer support agents.
To contact a Customer Support Agent, send a private message to them by clicking here. You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
