12-13-2025 10:07 AM
Will this phone work on public mobile 5g
12-14-2025 01:48 PM - edited 12-14-2025 01:48 PM
No official sources, but you can try cacombos.com. I can't vouch for its accuracy though. ENDC combo means NSA combo.
PM only has NSA. Telus and Bell have NSA and SA.
12-13-2025 11:13 PM - edited 12-13-2025 11:19 PM
any site that will list the Combo where a phone will use?
and PM's (or Telus' and Bell's 5G) is only 5G NSA?
and how can i check the NSA combo my phone current using to access 5G?
12-13-2025 11:10 PM
@2_ the only 5G bands that your phone can use would be n77 and n78. But due to the nature of 5G NSA, it'll need to be supported in a specific combo with LTE in order to work.
For example, if your phone supports B2_n78 or B7_n78 as a combo, it will work. The specs don't list the combos so there's no way to know. If I had to guess I would say you won't be able to use 5G with your phone in Canada.
12-13-2025 12:33 PM
these overseas target phones won't well 100% in North America. Get a phone that actually marketed here
12-13-2025 10:11 AM
@2_ on paper, it should work.
But PM starts retiring 3G network slowly and subscribers are recommended to use phone that is VoLTE compatible with PM network to avoid voice issue. (please note the phone could have VoLTE but still not compatible with PM's)
I don't believe your phone's VoLTE is compatible here, but check here to confirm:
https://www.publicmobile.ca/en/get-help/articles/volte
If it is not VoLTE compatible here, you will have to use 3G network for voice but the 3G coverage is shrinking, e.g, Manitoba will not have 3G starting Jan 2026
12-13-2025 10:10 AM
Hello.
Please enter the IMEI number into the link below. This will tell you if it's supported or not. But I'm sure it won't be.
