Trouble With Phone Transfer
Pam123410
Hi there I just signed up for a plan. I opted for an esim. After inputting my previous carriers account number the Public Mobile App put me into a login loop asking me to verify my account. However, to verify my account it would send a text to my phone number being transferred which isn't coming through. I also haven't received a transfer request from my previous carrier either. Not sure what to do!
2 REPLIES 2
eddieO
@Pam123410, to confirm, did you leave your old carrier's SIM card in your phone to receive the transfer request confirmation? If the porting hasn't taken place yet or you haven't responded "YES" because the message did not go through then you need to make sure the old SIM is still in your phone. After responding YES, you can then remove the old SIM
HI @Pam123410
so, have you got to the last step of the activation?  But it sounds like you didn't and I don't think the porting request was successfully put in  (So, dont call the porting team yet, they can't help)
you will need support to help in this case,  you can submit  ticket by direct message:
