01-28-2025 10:59 AM
Hi there,
I am travelling and planning to use an e-SIM for my data coverage. My current plan is US/Canada. Do I need to do anything to prevent unexpected charges from Public Mobile? I understand that I will not be able to receive or take calls. If someone phones me what will happen? Can I check voicemail on WIFI?
Thanks!
01-28-2025 11:34 AM
PM is prepaid, and everything has to be paid before use, so, you don't need to worry about surprise charges
And PM only has roaming service in US and Mexico, no where else. If you need to check voiocemail, call using VoIP app like TextNox
01-28-2025 11:27 AM
@Andrew145 , there is no roaming fees or charges from Public Mobile. You can leaving your roaming on at all times you will not be charged.
If you are traveling outside of USA, your phone will not ring. Voicemail can only be checked by calling your number from another phone.
