Traveling to US
HMike
Do current Canada / Us plans include roaming and data when travelling to US?
hi @HMike yes, all included like you are in Canada
HMike
Great, thank you!
@HMike  Yes those plans have roaming built in to the plan . When in the U.S. turn roaming on in phone settings and set phone to 4G/LTE not 5G and make sure your connected to T mobile AT&T or Verizon . You can use this plan in both country’s to call to and from either country talk text and data . But also not if your phone is not in the PM voLtE white list you won’t be able to make calls in the U.S.
VoLTE white list
https://www.publicmobile.ca/en/on/get-help/articles/volte
Phil_Adelphus
@HMike   Yes they do.  You may get a text offering a roaming add on as you cross the border but that it send to everyone and you can ignore it.  For voice calls you do need a PM approved VoLTE phone since there is no more 3G in the United States.
