11-02-2024 11:44 AM
Have selected the $20 3GB plan that appeared on my account. I initially selected the change on renewal option but not wish to update to this plan immediately and not wait until the renewal date.
I can’t seem to find an option to do this . I have messaged CS and waiting for response.
a month ago
hi @Immune ask CS Agent to escalate and check your account activities. They should be able to traxk4
and a lesson for next time, always take and keep screenshot just in case
a month ago
There is nothing CS can do- since it’s gone it’s gone .
11-02-2024 12:03 PM
11-02-2024 12:01 PM
I looked into what you suggested but when I do that the $20 plan option is no longer available.
11-02-2024 11:55 AM
You should be able to cancel your plan change.
Then choose the $20 3G plan option again and this time, change immediately. Note: Public mobile will not pro-rate plans. You will lose whatever is remaining in your present plan.
