Traveling to India
RogerPete
Hi Team,
I am using your e-sim and I wanted to know if I can use your sim internationally.
I am traveling to India and wanted to use the services for calling within India. Let me know if I am able to use Public Mobile there and if yes, what are the charges respectively.
Thank yoU!
Chalupa_Batman
Hi @RogerPete
Just adding some info to help.
https://abrokenbackpack.com/india-sim-cards/
Also, you could also download a VOIP app like TextNow or Fongo so you can make unlimited calls back to Canada using WiFi out there.
hairbag1
@RogerPete
will you have access to good wifi whilst in India ? If so, consider downloading free TextNow app to your cell phone. Using your wifi, you'll be able to call and text most any US and Cdn number for free. You select a temporary Cdn number so others can call you...for free too. It's an inexpensiveness alternative.
@RogerPete  No sorry PM won’t work in India . Just Canada and the US with US roaming . Your best to get a local prepaid SIM card in India .
