02-26-2022 12:45 PM
How do you add on US voice and data to an existing plan?
02-26-2022 02:38 PM
You will only be able to use you voice services with T-Mobile for the next few months due to the decommissioning of the 3G networks in the US. At&t has already shut down their 3G network so you will only be able to use data and/or text services on their 4G LTE network.
02-26-2022 01:07 PM
Thanks! That's helpful.
02-26-2022 01:03 PM
Purchasing an add-on after logging in into your PM account is a two-step process. You need to load funds first and then purchase add on.
US roaming Talk cannot be stacked. Next one has to be purchased after initial expire but you have to wait 24 hours.
When you are in US, try to connect to AT&T or T-mobile. One could be better than the other so, if one doesn't work well, try the other one.
US Roaming for 10 day packages
Unlimited U.S. Talk, Text and 250MB Data Bundle = $20
Unlimited U.S. Talk and Text Bundle = $15
Unlimited U.S. Talk Only = $8
Unlimited U.S. Text Only = $8
U.S. Data Only for 10 day packages
250MB = $10
500MB = $15
1GB = $20
02-26-2022 12:57 PM
Hi @Elizabethseib You can buy US roaming Add-on.
First login to My Account, check the list of US Add-on you want to buy. Then load enough fund into the account first. After fund is loaded, go back to the list of Add-on and purchase
Once done purchase, reboot your phone. Also, on your phone, use Manual network selection and try to connect to T-Mobile or AT&T, either one as long as you can connect. If you are buying Roaming Data, also make sure your Roaming Data is enabled on your phone.
Let us know if you have any trouble buying or connecting.
02-26-2022 12:52 PM
@Elizabethseib wrote:How do you add on US voice and data to an existing plan?
@Elizabethseib you need to purchase ROAMING Addons for services to be used in USA. But they only work while you are there. Addons last 10 days, and start as soon as you successfully add them to your account.
Log into your account to see the ROAMING ones available:
OR call 611 from your device.
02-26-2022 12:50 PM - edited 02-26-2022 12:53 PM
HI @Elizabethseib The only way to do is to buy 10 days roaming add-ons. Please note the add-ons are 10 days and you have to keep buying if you are there for longer than that and want to keep using it.
here are the choices US roaming add-ons (expand to see):
Please note that buying add on is a 2 steps process,
1. load fund
2. add-on purchase
Many people missed step 2
and if you are in US for long time, I suggest you to buy local data prepaid SIM, it is cheaper and offer more data and easier to use. For voice call, consider using VoIP app like TextNow. You get to pick a Canadian number and you can make calls and receive calls for free
