02-07-2023 04:40 PM
Hello,My plan notes that "unlimited international text" is included. So does this mean that I won't have to purchase the $15 US roaming add on in order to receive/send texts while I'm in the US?
Thanks,
Javagirl
02-07-2023 05:09 PM
@LoveNature wrote:Hi @Javagirl
your plan unlimited international text in Canada, out canada service
you need to purchase the 15 days US roaming add-ons to receive/send texts/calls in the US and to call/text to Canada,
I guess the earlier replies weren't clear enough on those points.. However, OP will be able to receive texts without roaming add-on, just won't be able to text back without roaming.
02-07-2023 05:06 PM
Hi @Javagirl
02-07-2023 04:44 PM
@Javagirl You need US roaming add on for use in the US
02-07-2023 04:43 PM
Thanks
02-07-2023 04:43 PM - edited 02-07-2023 04:43 PM
No, the only thing you can do in the states with the Public service is receive texts. Sending and all calls and cell data need roaming add-ons.
Adding - one stupid little word
02-07-2023 04:42 PM - edited 02-07-2023 04:44 PM
@Javagirl Sorry, that is only for sending and receiving texts while in Canada. You'll need to purchase a roaming add-on in order to text back (although you will receive incoming texts without roaming add-on) or to make calls in/out when in the US.
edit: BTW, for calling you'll need to select T-Mobile and select 2G network.
02-07-2023 04:42 PM
Unlimited international text works while the customer is in Canada.
While traveling in the USA, you will be able to receive texts without a roaming package. However, if you want to sent texts, you will need to purchase a 15 day add on.
