11-13-2024 08:21 PM
While I am outside Canada and USA, presumably calls to my number will automatically go to voicemail. Will I receive any notification that a voicemail message has been left?
Thanks!
Service
11-13-2024 08:43 PM
Perfect!
Thank you.
11-13-2024 08:37 PM - edited 11-13-2024 08:40 PM
hi @cjmagor yes , you can forward you PM number to your Wife 's number
To forward all incoming calls to another number on Public Mobile, you can dial 21 plus the ten-digit phone number you want to forward to, plus "#" and then send
11-13-2024 08:32 PM
Thanks to all for the quick responses. Local eSim has already been purchased in order to be able to stay in touch. Is it possible to forward calls to my PM number to my wife's phone while I am away so they don't go unanswered?
11-13-2024 08:28 PM
to keep in touch with fam and friends at home in Canada, you could all download Whatsapp. You'll be able to talk and text using your local wifi while in Jam. Whatapp is free to use.
11-13-2024 08:25 PM
hi @cjmagor not Jamaica. PM has no roaming service there at all
11-13-2024 08:23 PM
@cjmagor No sorry PM only has roaming in the U.S. , for Janice your best to bet travel sim like airalo or buy local pre paid data am in your destination
