URGENT Phone number transfer fail
11-13-2024
02:41 AM
11-13-2024
06:17 AM
computergeek541
I have travel coming up to US tomorrow. Just transferred my phone number from FIDO to Public. The account has been transferred out from FIDO. But my phone shows SOS without signals, seems like esim has not successfully installed on my phone.
Joining Public
11-13-2024 04:34 AM
Good to know but I think that window has probably closed. But you never know?🤞
11-13-2024 04:28 AM - edited 11-13-2024 04:29 AM
hi @RavingRaven I notice that about the one time access code.
But from the community, I saw about 2 cases like this and they mentioned they can have access app to rebuy eSIM. I guess maybe if the app hasn't kick the user out yet , they have a short timeframe without the one time code. Just want to see if OP is another lucky one
11-13-2024 04:26 AM
I forgot about setting the Public E-sim to active advice. Thx.
But there's no account access until the OP can verify as the account holder via the one time 2FA code texted to the phone # after activation.
11-13-2024 04:21 AM
hi @Vony Android or iPhone?
First, remove Fido sim card if it is physical or disable it if it is a eSIM
Then for the PM eSIM make sure it is set to Active. Or on IPhone, make sure the PM eSIM is set to Primary and the option "Turn on this line" is enabled.
Then try Reset All Networks once or twice
if same, and if you can login the PM app still (for 2FA, choose to receive it via email), the you can rebuy a new eSIM from the Account page and setup a new eSIM. That usually will work. (you can ask support to reimburse you the extra eSIM cost)
11-13-2024 04:14 AM
PM did not send me an email contianing QR code
11-13-2024 04:13 AM
Good point. Can an e-sim not properly provision to an account at activation like a regular sim card?
You might as well contact customer support now do that you hopefully get a reply in time to purchase a Sim card (if needed) to ensure you have service before you leave for the US. If just provisioning is needed and/or scanning the QR code from your email then it's best to submit a ticket via the chat bubble below right on your screen or send a private message using the link below:
11-13-2024 03:55 AM
Did you try scanning the QR code PM sent to your email?
11-13-2024 02:50 AM
Uh oh this will be an issue. Your best bet is to purchase a Sim card from a Telus or Koodo corporate store or Mobile Klinik shop first thing in the morning and contact customer support to swap out the inactive esim. Once swapped out and you can access your account you should be able to purchase another esim ($0) to be installed on your phone and an agent will credit back the $10 you paid for the physical sim card. ( Save your reciept.)
If you're in the GTA then Public Mobile sim cards can also be purchased from Canadian Cell Supplies.
