02-15-2024 05:25 PM - last edited on 02-15-2024 09:07 PM by computergeek541
I wanted to make sure I wasn't going to accrue any extra fees or charges while traveling to Florida next week. I am already paying for free roaming in Canada and USA for call, text and data with my current subscription, right?
Thanks,
Maribel
02-15-2024 05:46 PM
HI @Maribel19
yes, you wiil be using PM's roaming partners T-Mobile or AT&T.
Your phone might not automatically changed it, so you might need to connect manually, try both and stay with the one gives you the best connection
02-15-2024 05:45 PM
So once I arrive to Florida, my phone will change to a different network it sounds like.
02-15-2024 05:40 PM
@Maribel19 You can test for voLTE yourself set phone to LTE and make sure wifi is turned off . Now make a call does the phone stay on LTE or drop to 3G ? If it drops you haven’t t got voLTE and you will have to use 2G T mobile for voice in the U.S. . If it stays on LTE you have voLTE enabled and phone set to 4G/LTE and just connect to T mobile or AT&T and you will be all good 👍🏻
02-15-2024 05:33 PM
HI @Maribel19
yes, you are all set if you have a Canada-US plan. Make sure you connect to either AT&T or T-Mobile, you might need to manually connect
and make sure Mobile Data roaming is enabled on the phone
Best to connect on 4G instead of 5G. So, make change to your Network mode and not use Automatic but choose 4G or LTE
for voice, will see how it goes, either VoLTE will work or you need T-Mobile 2G network
02-15-2024 05:32 PM
How do I check this? My subscription says: 50GB within USA and Canada
02-15-2024 05:31 PM
@fixin wrote:@Maribel19 - If you have a Canada - US Plan you don't occur any roaming charges, but if you don't have a Canada - US plan, you will need to get a Roaming Add-On for 15days. You will always receive calls even if you aren't on a Roaming Plan or Add-on. No roaming charges for Pay-Per-Use.
with all due respect ..this isn't the case. While in US, you'll receive text messages even w/o the add-on...just can't send texts. You'll not receive any calls in US unless you have add-on or Canada / US plan.
02-15-2024 05:31 PM
Won't get calls @fixin
You will get SMS texts, however, without a US roaming addon or plan. You won't be able to reply to the text, nor call in or out, nor use data.
02-15-2024 05:29 PM
@Maribel19 PM is prepaid and no surprise bills ever you can only use what you have paid for so no worries . Just remember when in the US you turn data roaming on in phone settings and set phone to 4G/LTE and connect to T mobile or AT&T . If you have any issues with voice try phone on 2G and connect to T mobile . Do you know if your phone /account has voLTE ?
02-15-2024 05:28 PM - edited 02-15-2024 05:39 PM
@Maribel19 - If you have a Canada - US Plan you don't occur any roaming charges, but if you don't have a Canada - US plan, you will need to get a Roaming Add-On for 15days. You will always receive Texts (EDIT: Sorry, I said 'Calls' instead of 'Texts' @HALIMACS ) even if you aren't on a Roaming Plan or Add-on. No roaming charges for Pay-Per-Use.
02-15-2024 05:27 PM
you are correct. In preparation, please make sure to enabled Roaming Data in settings. Also, confirm if your cellphone has volte enabled by PM.
02-15-2024 05:26 PM
Yes, there's no extra fees with Public Mobile as it's a pre-paid service. If you haven't paid for a service; such as US roaming you just won't have it; that's all. 🙂
