10-30-2023 05:31 PM
I missed the text from my previous provider in order to port my number. What do I do now?
10-30-2023 05:46 PM
Can you send me the porting number? Where do I need to go to be able to use the porting number?
10-30-2023 05:42 PM
Hello!
Please check your community mailbox as I’ve sent you the number to the porting department there.
This link will also take you right there:
10-30-2023 05:41 PM
Check your mail box top right corner
10-30-2023 05:38 PM
transferring to public mobile
10-30-2023 05:33 PM
If you're trying to transfer your number TO public mobile, I can send you the porting number.
If you're trying to port OUT your number to a different provider, then THEY have to send the request to PM.
