01-26-2026 09:46 PM
Hello,
I am trying to activate/transfer my number and cellular network to a new phone and I am having a lot of difficulty. I followed all of the steps and troubleshooting. Every time I try to install the new eSIM it fails and says "Error. Something went wrong. Please try again". It has failed more than 3 times and I have not received any QR code. I just want to use my new phone with my same number and subscription.
Thank you for your help!
Alexandra
01-26-2026 09:47 PM
hi @allykitkat
can you double check if the PM eSIM is already showing up on your Sim Manager or Settings-> Ceulluar?
if yes, then you need to manually enable it
but if it is not there you will need to ask PM support agent to help, you can submit ticket by direct message:
