Number transfer Issue
Kayjay717
Activated my account today and requested to transfer my number from Fido to public mobile. I got Fido message and responded YES. But public mobile sent me the below message and I entered the correct account number for my Fido        Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect account number. Someone from our team will contact you shortly using your original phone number or the alternate number provided. You can also get in touch via our virtual assistant at: https://urlshortner.tiia.ai/xYpc_I
2 REPLIES 2
hi @Kayjay717
It is  an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),  use this link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
please use the same Community account login you are using now to login and submit ticket
slusagm
There is a porting assistance team you can call and ask for help  I can't post the number here, but I will message the number to your community inbox.  Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link:
And CS_Agent will reply to your community inbox, check here:
