08-14-2026
09:50 PM
08-15-2026
10:32 AM
Dunkman
Hi there, can anyone help with an incomplete activation where it is stuck at the eSIM installation step? I tried transferring my old number but it keeps getting stuck at eSIM installation and now it is not giving me any retry option other than contact support. But I can't seem to submit a ticket either for whatever reason even though I have filled out all the boxes. I also can't verify my account because the system keep saying I have to get the code from my number (which is no longer working because of the transfer). I've also tried rebooting my phone which did not work either. I also did not get a welcome email with a QR code. I've sent a private message in the community support and have not heard back. So I'm pretty much at a loss of what to do. Thanks for any help offered!
08-15-2026 01:11 AM
Thanks your answer also helps me.
08-14-2026 10:19 PM
@hTideGnow thank you I will try tomorrow!
08-14-2026 10:10 PM - edited 08-14-2026 10:10 PM
hi @LilW
it's 10PM ET, and support centre closed already. You will probably have to wait for tomorrow for them to contact you back
Check Expert Messaging ( https://publicmobile.ca/en/get-help/articles/expert-messaging ) in the morning and message them again
08-14-2026 10:08 PM
Thanks @hTideGnow , I tried all your suggestions before and nothing has worked unfortunately. Still waiting for my direct message to them I sent about 3 hours ago.
08-14-2026 10:06 PM
Hi @Chalupa_Batman I just tried this and it's taking me in circles as I didn't get an activation email with QR code (also checked junk and nothing). Now it is telling me to Log in to my Self-Serve account, but I'm getting this message "We’ve noticed you have an active Public Mobile service and would like to confirm your full access
08-14-2026 10:01 PM
you sure the esim not there? check Sim Manager, maybe it is there and the app cannot enable it
but if you need PM's help, Simply open ticket with PM using Expert Messaging. Click the Orange Chatbot icon on the lower right to start, or use this link https://widget.telus.tiia.ai/libs/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&lang=en&toggle=fal...
(For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.)
PM will reply you via Expert Messaging between 9AM-10PM EST (Mon-Sun)
(for help with Expert Messaging, check here: https://publicmobile.ca/en/get-help/articles/expert-messaging )
08-14-2026 09:59 PM
hi @LilW
If you got the error ""SUBSCRIPTION NOT ACTIVATED" or " Unable to Activate eSIM" at step 6, Reboot your phone, re-login and the app will try to complete the activation
If same, then remove the old carrier sim card, or if it the old carrier sim is esim, disable it from Sim Manager or Settings->Cellular
Then put the PM sim card in the phone, or if eSIM, you should be good
Next, go to Sim Manager or Settings->Cellular and check if PM sim is showing there. Make sure the Public Mobile sim is enabled , or Turn on this line option is toggled on. Also, change the label to Primary
Reboot your phone and Reset network settings and test and confirm if all work or let us know of if any the following does not work: inbound and outbound calls, inbound and outbound text, mobile data.
if the sim not connecting, ask PM support agent to help. You can submit ticket by direct message:
08-14-2026 09:57 PM
@LilW wrote:Hi there, can anyone help with an incomplete activation where it is stuck at the eSIM installation step? I tried transferring my old number but it keeps getting stuck at eSIM installation and now it is not giving me any retry option other than contact support. But I can't seem to submit a ticket either for whatever reason even though I have filled out all the boxes. I also can't verify my account because the system keep saying I have to get the code from my number (which is no longer working because of the transfer). I've also tried rebooting my phone which did not work either. I also did not get a welcome email with a QR code. I've sent a private message in the community support and have not heard back. So I'm pretty much at a loss of what to do. Thanks for any help offered!
Apparently this is the way to get a hold of support. However, some people have said it's been several hours with no reply. Not sure this new system is working but eh...
If you are able to log in, please use this link to the new Public Mobile Expert Messaging service. Follow the prompts to get assistance from a CS Agent.
