Transfer to esim from Koodo not working
caperme
It fails after accepting payment and me entering the phone # and iemi #
The notice is Subscription Not Activated.  Something didn't go right while activating your subscription.  Click below to contact a customer support agent.
2 REPLIES 2
@caperme
This should be an easy fix. Just contact a CS_Agent for help at:
@caperme  Is this Koodo pre paid like PM or post paid . If pre paid you need support to help you transfer the number . If post paid using the IMeI could be the issue it’s not needed ignore IMEI @caperme @and just give Koodo account number . I’ll send you the porting team phone number private message and they ca re trigger the port request for you
send  a  private message   To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
