Calls keep dropping
12-29-2023 04:30 PM
My calls keep dropping on my phone and my roommates phone that’s also on public mobile. Started within the last month. Also my voice cuts out or turns digital sounding when talking to someone on a landline. I also hear this on my end when talking to other people on cell phones.
Service
12-29-2023 04:45 PM
I’ll try that
12-29-2023 04:42 PM
Transferred over in the summer. And my roommate has been on it for a few years. This just started to both are phone recently
12-29-2023 04:38 PM
@KCats Try 3G first and test if it’s better leave there for a day or two and put it back to 4G/LTE is that what you usually have it set on
12-29-2023 04:38 PM
Hmm were you always with PM or you just transferred over? Did you experience this before?
Strange, don't know what to tell you😞. Hope it will fix itself soon
12-29-2023 04:37 PM
Nothing on the map. And it’s been going on for a month straight. I’ll try to set it to 3g or 5g
12-29-2023 04:35 PM
It could be a weak signal on 5G. Switch your Voice & Data settings to 4G/LTE and enable VoLTE.
12-29-2023 04:35 PM
Yes we both tried that and it doesn’t work
12-29-2023 04:33 PM
@KCats First check
Outage map in your area:
https://istheservicedowncanada.com/
also can you try the phone set to 3G or 5G and see if voice makes a difference
12-29-2023 04:32 PM
That sounds weird.
Have you tried to reboot the phone to see if that might help.
