11-26-2024 03:36 PM
I ran into trouble during porting my number to PM from Lucky mobile:
During the process the PM app gave instructions “not to minimize or log out of the app”. Therefore the PM app installed the PM eSIM before I could confirm the transfer by responding to the Lucky text.
I am now in limbo with PM data working but still not transferred from Lucky. I finally got my texting working by switching back to the Lucky eSIM so that I can login here!
How do I redo the transfer? I do have a ticket submitted now.
Service
11-26-2024 04:47 PM
Yes, I finally got my phone working with PM! That was a long haul!
Second phone call to Koodo/Telus was much better - more helpful person. Probably real help came from opening a ticket here.
I got caught in limbo and couldn’t receive texts due to PM app instructions not to minimize the app during the transfer process. This caused the eSIM to switch over to PM before I could respond to Lucky SMS to authorize the transfer. After that texting didn’t work so I couldn’t do anything, couldn’t login here to get help, etc. Until I got the idea to switch back to Lucky eSIM. Then I could text again and resolve this. Thanks everyone!
11-26-2024 04:29 PM
You can have the E sim installed from PM and still get texts from your original carrier if the line is still active. I would double check your sim settings. I had to turn off the PM sim and turn on the previous carrier sim to get messages and calls until the porting was complete. I too thought something was wrong but the texts were going through to the correct number wrong carrier. I hope this is helpful !!
11-26-2024 03:45 PM - edited 11-26-2024 03:45 PM
hi @mva5 trust me, that team can help. Call again as that is the faster way
11-26-2024 03:43 PM
I did try that phone number without success. Maybe I should try it again. They said they could not help.
I have messaged an agent. I probably need to wait longer for the response.
11-26-2024 03:42 PM
hi @mva5 call them back, they can help
Check if them to confirm if the information was correct and they can resubmit the port request. Once they sent them port request again, you will receive a text shortly on your old carrier sim card and you can reply yes
11-26-2024 03:41 PM
11-26-2024 03:39 PM
Did that and they were unable to help me other than to tell me that the porting was unsuccessful.
11-26-2024 03:37 PM
hi @mva5
check with PM porting support team and confirm. I will send you the number to PM Porting support team Please check your community inbox
