a month ago
a month ago
@Keeps12x wrote:So I have a 2 step login. One to my email than to my number that’s with the esim . Esim phone is busted so I have another phone and I got a new sim to transfer but can’t . Only way to login is get that number going .. need help from an administrator it seems… Any help will be great
If you use the e-mail option, does that work?
a month ago - last edited a month ago
@Keeps12x Try hitting "Didn't get the Code' a few times and it should give you the email option. Or do you mean you can't access the email without the phone?
a month ago
a month ago
Why can't you get in can you provide a little more info?
