Number transfer
Calgal
I followed all of the steps necessary to transfer my number from TELUS to PM, I got the verification text from TELUS asking if it’s me that was doing this transfer. Answered Yes to it within the 90 minutes but I haven’t received a confirmation from PM yet. It’s been about 11 hours since I started the process. My TELUS SIM card is removed and my phone seems to be working correctly.
Calgal
Thanks everything looks good when I checked it looks the same as the screenshot you sent me.
looking forward to saving some $$ every month
@Calgal  Then check phone setting and make sure the PM eSIM is enabled / set to primary or if iPhone that you toggle on “turn on this line “ and reset network settings and test again
Toggle on
“Turn on this line”
HI @Calgal
remove the Telus sim card first
make sure the PM esim is set as Primary (or enabled) and enable "Turn on this line"
try reset network settings once more and if still same, reboot the phone once more
last, call porting team and ask.  I sent you the number already
Calgal
Thank you, I did reboot my phone but it still had the TELUS SIM in it at that time. I’m using an eSIM with PM.
HI @Calgal
have you tried reboot your phone with the PM sim card inside? if not , please try
or It could be an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (envelope on top right), check for the number and call
