Transfer number incomplete
Lynda4521
Why has it been longer than 5 hours to have my number transferred from Virgin Mobile to Public Mobile?
7 REPLIES 7
@LozzaS   done.  Please check your inbox
LozzaS
Hello,
Please can you message me the number to call the public mobile porting team to retrigger this process? My partner is also having this problem and cannot receive any inbound calls, texts or 2FA texts. He is currently using his old phone and paying for 2 phone contracts!! He has contacted public mobile with support tickets and nobody is getting back to him.
Thankyou
@JC89 sent!! Check your inbox
JC89
Hi, I am also having problem with porting my number in. It’s been a few hours and seems like the porting might need help from the porting team.
Can you please also inbox me the phone number to get assistant from the porting team?
Thanks!
Dunkman
@Lynda4521
Did you response yes to the Virgin Mobile port request text?  Is your Virgin Mobile account active?  What happens when you put your PM Sim card in your phone?
Here is some information:
https://www.publicmobile.ca/en/on/get-help/articles/number-transfer-port-troubleshooting
HI @Lynda4521
you got a text from Virgin? did you reply YES?
If you did, reboot your phone
if you didn't reply , or reboot does not help, Call Porting team.  I will message you the number.  Check Community inbox
@Lynda4521
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins.  If you are not receiving calls and text on your PM sim card, and only outgoing calls, wok  then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
