05-29-2023 12:59 PM
I registered for PM's $25 for 3GB for 12 months plan in October 2022. Now it's the 8th month I have been using this plan. However, today I just checked that there is no longer a promotional data section of 2GB in my account. Could someone working for PM fix this error for me? I would like to keep having my promotional 2GB for the next four months!
Service
05-29-2023 02:14 PM
nice trick @esjliv
@Anonymous the long way, 3 dots on top right, select New Incognito Window (Tab) or Private browsing
05-29-2023 02:12 PM
@Anonymous wrote:Hi, could you please tell me how to check using Incognito mode?
@Anonymous You can also use a keyboard shortcut to open an Incognito window:
Windows, Linux, or Chrome OS: Press Ctrl + Shift + n.
Mac: Press ⌘ + Shift + n.
05-29-2023 02:10 PM
05-29-2023 02:07 PM
@Wheels1 that was not a one time bonus. OP was talking about this promotion
@Anonymous , yes, it was a 12 months for 2GB extra. Can you check again using Incognito mode and confirm if 2GB is there? If not, yes, message support and they should be able to add it back.
Again, message them here:
05-29-2023 02:05 PM
No that's not true. The promotion I got is 2GB extra per month for 12 months
05-29-2023 02:01 PM
The 2gbs are only a 1 time promotional add on. Once you’ve used the full 2 gbs it’s gone 😞
05-29-2023 01:22 PM
We are just customers here:
05-29-2023 01:15 PM
@Anonymous Get support to investigate
- while your already here and logged in the community
- you can send a private message To CS_Agents by clicking >>>>>>>>here.
Watch for reply top of page to the
Right ( envelope image )
