6 hours ago
- last edited
6 hours ago
computergeek541
Trying to transfer my bell number to public mobile but not having any luck…
Any help out there
3 hours ago
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
6 hours ago
Are you using the PM app then select a subscription and create a new account?
Download the app on the phone you are using and complete to step 6.
6 hours ago
6 hours ago - last edited 6 hours ago
Hey @Lorne47
Sometimes it's just easier to get a temporary number, then once everything is up and running, then transfer it over. Just make sure you other account is still active.
6 hours ago
@Lorne47 wrote:Trying to transfer my bell number to public mobile but not having any luck…
Is the number coming from Bell Canada or Bell Mobility? Transfers from landlines take a few days. For transfers from a wireless carrier, a text message will be sent by the old carrier for you to reply to and approve the phone number transfer. Did you receive that text message?
