11-28-2024
11:35 AM
11-28-2024
01:32 PM
computergeek541
Hi, it's been 14 hours since I started the transfer process for my mobile number. I have followed instructions to a T. Can someone help please.
11-28-2024 01:35 PM
hi @dravi
sent. Only call if you are make outbound calls but not receive inbounds
11-28-2024 01:29 PM
I am also facing the same issue.. Can I get PM porting support number?
11-28-2024 12:05 PM
Thanks for the numbers, have called and they report that Rogers claim that they never received the authorization message, despite me having evidence that they did.
Have re-initiated port, hopefully this resolves.
11-28-2024 11:36 AM
Sounds like a port gone wrong. I will send you a message with a number to call/ Check your envelope.
11-28-2024 11:36 AM
hi @EdmundA
first , make sure you can make outbound calls. If just not receiving inbounds, then yes, porting was not done
PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
