Re: Transfer Number
Joe077
Is there a way for me to transfer over my number from my home landline from my work location? I would like to replace my public mobile number with my home number, and make my home number accessible on my cell phone.
Thanks,
You do not have to be at home if you are transferring Land line to mobile.
You just have to log in to your Public Mobile account. Mind you, calling Telus will NOT help you as Telus and PM are two different units and support is different.
Usually when people port mobile to mobile PM provider sends SMS to authorise transfer. In case of land line transfer it is a little bit different and longer.
Joe077
I'm at work, can I do the transfer of my home number without calling TELUS. I am not physically where the landline is.
Yummy
Yes, you can port any eligible number to PM to be on your mobile phone. Before you initiate transfer check if your number is eligible.
Eligibility Check: if your existing number is eligible to move visit This link (Koodo, Public Mobile and Telus are the ‘same’ company).
Log in to your account and go to:
Profile, where you can:
- Change phone number
- Change SIM number
- Transfer Phone Number
Be advised that porting land line might take up to 7 days (or even longer). You might notify your land line provider you will be transferring your number so they do not reject request from PM.
