12-29-2025 11:59 AM
1. I used the Public Mobile to create an account & buy eSIM
2. I submit a transfer for my Rogers Phone number
3. 5 minutes after, I receive a txt from rogers and confirm my transfer request. I reply YES
4. 95 minutes after, I received a Public Mobile txt message that "we have not received your response yet". I call the Public Mobile 1-800 and it indictes I do not have a transfer request for my phone number
I resubmit a transfer request and the issue re-occurs. Please help?
12-29-2025 02:18 PM
Hi
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
12-29-2025 12:26 PM
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
But if you are unable to reach someone from the live support with the phone number I sent you, you can also message them here:
**After opening the ticket, please monitor your community inbox (envelope icon on the top right), the customer support agent will get back to you in sending a message there.
12-29-2025 12:22 PM
Hello @Shelley1974
Please go to your mailbox here. I will send you a number to call to get help.
