11-24-2022 01:15 PM
11-24-2022 01:47 PM
@nsherzai...
PM is a do-it-yourself type of cell company. You have to be able to explain in detail, what you want in order for someone to help you. There is no phone in support...only on-line 24 hour / 7 days a week...Christmas too !
You also have to be knowledgeable enough to create your own account...there's tons of instructions but you have to do it yourself with our help. Be able to follow instructions after you ask a question.
If you can't do it...you're probably better off with a cell company with phone support...but it'll cost more than PM.
11-24-2022 01:23 PM
for easy way, just message CS agent:
but remember to check Community inbox for their replies.
11-24-2022 01:19 PM
Could not work, I am not too good I want easy way
11-24-2022 01:17 PM
HI @nsherzai
so, you never have a My Account login?
You can open ticket with PM CS agent and they will check for you to see if you have one, or create one for you
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
