Transferring Number
Mobina
I transferred my number from Bell to public mobile and I received the authorization message as well and replied YES to it then changed my old SIM to public mobile SIM. However, my number has not been transferred yet and it's been more than 5 hours. I don't want to lose my number and want to transfer it. If someone can help I would be thankful.
Piper2025
I’m having the same issue.  Did you get yours fixed?  What did you have to do?
hi @Mobina
not normal.  They usually reply quick, within 2 hours
did you check the Community inbox for CS_Agent's reply?
if not reply there, message them again for update:
and I will send you a number to call porting team to confirm if the port was completed.  Please check your inbox for my message
Mobina
I submitted a ticket and also contacted customer support agent about 7 hours ago but still didn't receive any feedback from them. Is it normal to wait for this long for a response? is there another way to contact customer service?
@Mobina wrote:
Thanks for replying. I tried to submit a ticket; however, I don't have the 19 digits behind the sim card.
I'm unsure as to why the system would be asking for your SIM card number. It should simply be asking you to log into your Public Mobile self serve account.  Since that step isn't working, send a private message to CS_Agent.  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Mobina
Please use the chatbot at https://widget.telus.tiia.ai/publicmobile/publicmobile.html to contact a Public Mobile customer support agent.
