08-16-2022 08:33 PM
The website doesn’t allow me to change my plan. It keeps saying “oops something went wrong, please try again later”, every time I click complete payment. I’ve tried for months to change my plan, and if I can’t by the end of this month, I will definitely be leave nag for a better service provider
08-17-2022 05:57 AM
@Timer wrote:review this Solved: Trying to change plan - Community (publicmobile.ca)
Unfortunately, instructions about how to use the arrows to select a new plan don't a help a customer when the person is seeing a website error message.
08-16-2022 08:44 PM
08-16-2022 08:42 PM
@Fow hi try clearing your cache and cookies or try a different browser in ingognito or secret mode also try on a different device if available if problem persists
you need to contact a customer service agent to explain your issue
you will need to open a ticket, to speak to a customer service agent Click here you can check for a response in your community envelope top right corner next to your avatar, or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
08-16-2022 08:41 PM
@Fow Open the self-serve portal using incognito or private browsing mode and try changing your plan again. The explained issue is usually cache/cookies related and opening it in a cache free window often resolves the problem.
08-16-2022 08:36 PM - edited 08-16-2022 08:41 PM
use browser from computer, clear cache and cookies and use one page inPrivate mode,
To Login Page
and use the down arrow to scroll down.
Edit: if choose to change immediately then losing payment paid for old plan and no refund and no adjustment,
or choose your next plan renewal date. To change your plan. to you not losing any money.
