Roaming to USA
Vdove
Does anyone know how to add roaming and costs from Canada to USA without having to change the monthly plan?
RavingRaven
@Vdove
You can also redeem points for US Roaming add ons at a discounted price compared to purchasing. Check your rewards account. Redemptions also start the 15 day countdown clock immediately.
hairbag1
@Vdove
using laptop, log in to your account > Subscription and Add-ons > Shop Add-ons...look over the 15 Day US Roaming options to make your selection. Remember that your 15 Days start as soon as successfully purchased. You will need a VoLTE enabled cellphone for use in USA as their 3g networks used for calling has been retired. Make sure to enable Roaming Data for data use.
eddieO
@Vdove if you go to the Shop Add-Ons section under the Subscription tab, there is an option to buy US roaming with data, see below:
If you're looking to just be able to call there is also an Add-On for 1000 U.S. long distance minutes for $15
