03-16-2025
09:11 AM
03-16-2025
11:39 AM
Dunkman
Last night my phone was working fine. This morning it was not able to see the Public Mobile network and I can't get it to show up in the list of available networks. My account is okay and I have paid all my bills.
03-16-2025 04:27 PM - edited 03-16-2025 04:28 PM
have you try submit ticket with PM agent for help? They can assist and confirm if it is just a local network problem. Remember if it is just a outage, it could be fixed soon. Things like this happen to any carrier.
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
03-16-2025 04:26 PM
Okay. If I take my phone 0.5 km down the road it detects and connects to Public Mobile and works as normal but uses a lot of power up and kills the battery quickly. As soon as I go home and wait a few minutes, the network vanishes and I'm stuck with no service. Since I've had no issues until this morning I have to believe there were coverage changes by Telus/Public Mobile.
Since I there is no way to speak with someone from Public Mobile and the only support is a useless Chat-bot or fellow customers, both of whom can only suggest I restart the phone or check the network settings, I am going to investigate and move to a new service provider. I thinking https://www.nonamemobile.ca/en/. Heading to No Frills now.
03-16-2025 11:52 AM
Did you also try the network reset of phone? Note: this will erase any saved Wifi passwords.
If you have a physical SIM card, you can also try the SIM card in another working phone. This will help determine whether hardware issue versus PM service problem.
03-16-2025 11:51 AM
Public Mobile support is absolutely useless.
03-16-2025 11:47 AM
I've restarted my phone numerous times and the Public Mobile network was unavailable. I checked Public Network and Telus and no outages were showing for my area (Sarnia). I was able to get Public Mobile (US) to show up briefly after my phone accidentally connect to the T-Mobile network. I also received a text message from Public Mobile indicating I would require a US roaming package. I live in Sarnia and have been using Public Mobile without issues for a couple of years now.
03-16-2025 11:04 AM
Also might want to check to see if there is an outage in your area.
03-16-2025 09:42 AM
@c0219619xcfbg Have you tried restarting the phone, and reset network settings?
