yesterday
Back in Jul 2024 I bought a UK minutes package. I used a few at the time, but none since. Now, that minutes package doesn't show up in my add-ons. I thought minutes like these rolled over indefinitely and didn't expire?
Add-Ons
yesterday
Found it, thanks!
yesterday
hi @Kev99
the addon should be there, click "Usage Breakdown" under the usage odometer on the Overview page. You should see something like this and the addon should be there
if not there, ask PM support agent to check
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
