03-16-2025 03:22 PM
Last night I made a 911 call to report shots fired near my house. About an hour later I noticed I had received a voicemail back from emergency services telling me they had investigated but found nothing. I had the phone in mt hand all this time and it did not ring! I looked into a message I got and it said all calls were blocked for two hours after a 911 call, "to allow you to concentrate on the emergency"! They evidently did not even allow emergency services to call me back but did allow a voicemail to be left!
Is this a feature of Public Mobile or a law or what? Is it something that can be turned on or off?
03-16-2025 05:39 PM - edited 03-16-2025 05:40 PM
@kb_mv Good find. That definitely seems like it.
@Croft Apparently Samsungs unblock any blocked numbers in your phone for 2 hours. There must be another reason why the call went straight to voicemail, such as a temporary drop of service.
In any case, the message you received has nothing to do with Public Mobile.
03-16-2025 05:21 PM
Everything is working now. I will try to formulate an intelligent question to submit. Thanks for the suggestion. I have only called 911 twice in 25 years.
03-16-2025 05:17 PM
It was a message that I had to scroll down to from on the home page of my phone. I tapped on it and it took me to the explanation which I may have misread. Another massage was that Emergency Services had requested my location which I think is related to the 911 enhanced service.
03-16-2025 05:11 PM
Samsung S22 phone. You may be correct in it referring to unblocking calls, it was about 1:00 AM at this point.
03-16-2025 04:08 PM - edited 03-16-2025 04:27 PM
@Croft Are you sure the message wasn't regarding "Un"blocking all numbers for the reason below? Sounds more of a phone issue than Public Mobile.
03-16-2025 03:38 PM
I've never heard of that, nor have I ever experienced that after having placed a 911 call. Seems like it would add more risk to the situation, not less.
What do you mean when you say you "looked into a message I got and it said all calls were blocked for two hours after a 911 call, "to allow you to concentrate on the emergency""? Who sent you this message?
03-16-2025 03:25 PM
hi @Croft
do you have inbound calls working now?
i think it is better to ask PM to confirm. Please check with support agent
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
