Text
06-17-2023 01:08 PM
Once a day I try to send a text,but it tells me ,Text can't be sent until service becomes available.Why is this
Service
06-17-2023 03:40 PM
@dust2dust To be honest, I only posted that information to add to available troubleshooting information for future posts, not that I make any assumptions that the user is experiencing that. It is up to the original issue poster to come enlighten us as to what is going on with their account, be it device related or otherwise. I just wanted to inform the community of that issue with android 14 beta 3/3.1 first and foremost.
06-17-2023 03:10 PM
Some people don't like likelihoods and conclusions drawn out of thin air without all the facts. Here, I think it's likely that the account is suspended. But that's why I ask the questions to get to the point of making that deduction.
@XionBunny- said the likelihood was low and all kinds of disclaimers of maybe only very few people might experience it. Other people say it's likely. Big difference. The former allows the possibility. The latter is asserting something that they don't know and sound all honest and then the customer might look at the Mayor designation and think there might be some weight to it. No. We need facts. The customer has not returned to provide them.
Here's how I might have worded the same allegedly innocent intent. "Honest, it feels like it could be a device issue". Or "Honest, I wonder if it's a device issue". It's also kind of a problem with using the word "honest" or "honestly" to begin with. Does that imply the rest of ones comments aren't so honest? And then oh but now I'm being honest because I started a sentence saying honest?
Throwing in "likely" while asserting doesn't work. What did Handy1 say the other day while graciously accepting a correction of wording - something like - words are important. Indeed.
06-17-2023 02:39 PM
@softech I was just highlighting a current bug on android with 14 in testing, some might be on the beta program, only saying in that situation it's not the fault of any provider.
06-17-2023 02:35 PM
@XionBunny be careful, some people do not like us talking "likeihood"..lol
But what you said is truly possible. Before PM opened up 5G , it was a big problem, especially on iPhone. Now with it open up, look like the iPhone issue is gone. But I know it still an issue with some phone, especially if the OS is not up-to-date. I hope OP has a newer phone with latest OS
06-17-2023 02:30 PM
@softech I know the likelihood of this is low, but users of the current android 14 beta build will find on Telus and other Canadian networks that when 5G is enabled data text and calling no longer function until 5G is disabled. That is due to a current bug since the beta 3 build was released. I'm only posting this to make everyone aware that could be a scenario that happens with a small percentage of the user base.
06-17-2023 02:22 PM - edited 06-17-2023 02:25 PM
Never any conclusion but some of use are putting our heart out and try our very best to help based on the information provided.
another likely situation is you have an MMS message stuck there
This could be because the MMS or multimedia messaging feature is not set up on your phone or you don’t have mobile internet enable.
Tru to enable Mobile network and see if the message goes away
06-17-2023 02:15 PM
Are you using iMessage in an iphone? Maybe you don't have it set to fallback to SMS when there's no data connection? Or similar settings for RCS fallback to SMS on an Android?
06-17-2023 02:01 PM
Hi @maryheavyn when you get the error again, check if your phone is connected to the network. Maybe you have weak signal and lost the connection?
06-17-2023 02:00 PM
Most likely you do not have string signal with the network.
Can you make/receive calls? Internet working?
06-17-2023 01:24 PM
I'm not ready to conclude any honest likelihoods until we get further clarifications from you.
06-17-2023 01:20 PM
@maryheavyn but you can receive and send without problem after?
voice call all good?
what brand and model is your phone?
I would try to click Reset All networks once. Please note that it will delete your saved wifi and Bluetooth connections and you need to add them back after
Also, see if you can arrange another phone to test for couple days. Honest, it is likely a device issue
06-17-2023 01:15 PM
Are you receiving real sms texts? Able to make or receive calls? Use the internet on cell data (not wifi)?
