06-16-2023 11:50 AM
My account says I'm out of data. 15 gb. In my usage it does not add up.
I have not used 15 gb of data.
Please help me restore my data.
This has happend for three months in a row.
06-17-2023 03:44 PM
I have done all of those things. My plan renews on the 26th of June. I am out of data but have not used the data myself.
06-17-2023 03:43 PM
It's an iphone and that's not the issue. I have never had this problem before except last two months.
06-16-2023 09:08 PM
what's the name and model of the device? if it's an android, one needs to make sure the "mobile data usage cycle" is set to the correct date the plan cycle started. at PM each cycle is 30 days so the start date will change depending on how many days in the month there are. since June only has 30 days you can call 611 and it will tell you when your account renews. whatever day it says is the the day you want to set your "mobile data usage cycle" too. then July has 31 days so in August you will need to adjust this setting again for an accurate reading of your data
06-16-2023 03:15 PM
Check how much data usage is being recorded by your phone. What phone do you have?
There is also a “Switch to Mobile data” option under Wifi settings, turn this off if it's on right now.
06-16-2023 12:49 PM
I have also done this.
In the end, I am suppose to have 15gb of data per month. My account says I have used it all up.
I have not.
06-16-2023 12:48 PM
Done, still the same. Either way right now I have no data, even though I did not use it all.
06-16-2023 12:48 PM
I have done that, still says I'm out of data. The prolem is my data is gone but I have not used. it.
06-16-2023 11:54 AM
@Jamesbenoit99 To rule out browser cache problem and you were reading old outdated/cached info, please login to My Account again using Incognito mode and check the usage again
06-16-2023 11:51 AM
Clear your browser cache and open a new browser window in incognito. Tap the spinner icon to refresh the usage.
06-16-2023 11:51 AM - edited 06-16-2023 11:56 AM
try logging in to your account on a laptop and try this to see your data remaining..
added...
log in to your account > Subscriptions and Add-ons ...just to confirm you have the plan you think you have..,
