Taking money from my account
Lakee8
I am not with Public Mobile. I attempted to port my number to them and it was unsuccessful. They have now taken two payments from my account and of course you can't talk to a live person at Public. How do I block them from taking money?
@Lakee8  - when you receive a charge for a Public Mobile SIM card activation, then the activation on the Public Mobile end of things was successful.
What occurred after the activation that did not work, or made you think you did not activate successfully?
Log into your account and see what information you can find out:
https://selfserve.publicmobile.ca/
Or register for one here:
https://selfserve.publicmobile.ca/self-registration/
Under the "Plan and Addons" TAB you will see a phone number listed. If it is not the one you tried to port over, then your port likely failed, and Public Mobile would have assigned another number to the account.
You can still port over your number into this Public Mobile account, if you still have your SIM card.
If you don't have your SIM card, you can obtain a new one, and swap the SIM card number in your Self Serve account.
If you decide against Public Mobile then remove your credit card if you registered one for autopay, and the plan will be cancelled after 90 days of nonpayment.
Hope that makes sense.
Customer Support Agents (CSA) contacts are found in the Get Help Articles here: https://publicmobile.ca/en/ns/get-help/articles/contact-an-agent
 @Lakee8 : Yes it does sound like you did successfully activate an account. It would then seem that maybe the port failed. Or the phone was incompatible. Or the phone number was not able to be transferred. Or the phone was locked. Or the phone is on the blacklist.
Did you activate in a store or yourself online? If yourself then you would have created a self-serve account with an email address in that process.
Do you still have the Public Mobile SIM?
Yummy
A little bit confusing statement.
If you tried to port number to PM that means you DO have account with PM.
If you provided credit card number while opening account and got charged but have service that would mean your port failed.
Please clarify what is your status with PM.
To stop getting charged by PM, remove your CC info from your account.
If still have account or porting issues, contact agent:
Send a private message to the CSA by clicking https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CountyDownIeUk
You must have then created an account and may have another number. Do you have the details to login to My Account? If yes remove your credit card.
Lieux
@Lakee8  Sorry for this problem. You need to reach public mobile to receive help with that kind of problem. Click on the chat bubble and write your problem. Search the CONTACT US button and the SUBMIT A TICKET button. They will help you.
BeachNBeer
@Lakee8
Contact customer service agents.
Open a ticket via:
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time)
Type "ticket" > Click "Contact Us" > Select your issue > "Click here to submit a ticket↗"
or send a private message to:
and describe your issue. Include your name,phone #, account #, Email address,4-digit PIN to speed up authentication process.
