Switching plans
Victor8561
If I switch to another plan do I still keep my current promotional discounts such as the loyalty and refer a friend discounts?
dabr
@Victor8561    Which plan are you wanting to switch to as I noticed PM has added a brand new plan (actually 2 new options but one is cheaper but same features if you chose 90 day payment cycle) in self serve, the 30 day plan is available for $45.
replaced screenshot
e
@Victor8561  Absolutely I can confirm , I just switched to the the new $39 20GB plan and I kept mine .check it out 🙂
@Victor8561
All your Rewards will transfer over to the new plan except if the previous plan have conditions. Eg 5gb for 5 months with $XX plan.
HI @Victor8561  Yes, you will keep your current promotional discounts such as the loyalty and refer a friend discounts
I did it to and  I can confirm all good
@Victor8561 loyalty and refer a friends rewards will not be affected when you do plan changes.
Just make sure you don't sign up for Public Points!
@Victor8561   Yes, Changing plan won't affect your rewards.  So, you will be on the old rewards system and you will get to keep the same loyalty and friend rewards
