10-20-2022 11:11 AM
Simon says I will still get my rewards. The promotion right now is basically I will switch from 3g to 4g and the price stays the same as well as my rewards. So What I am understanding is I will get 4G for the exact same monthly price?
Please confirm.
Plans
10-20-2022 11:25 AM
Rewards are tied to your account not plan.
Therefore if 4G plan is the same price as 3G you can switch and get faster Internet.
10-20-2022 11:20 AM
@Murse20 hi your rewards won't be effected and depending on the plan you picked price will be the same
10-20-2022 11:13 AM
@Murse20 If the new plan is the same price, then yes
![](/skins/images/97D9FB88C915001D8DAED89DBB2650DF/responsive_peak/images/icon_anonymous_message.png)
