02-23-2024 01:07 PM - last edited on 02-24-2024 01:31 AM by computergeek541
Hi,
I was on the $50 us Canada plan where it said us data. I switched to $40 us Canada plan and it says 75 GB but no mention specifically about us data. Just want to make sure US data is included...anyone know?
edited by computergeek541: changed label as the discussion is unrelated to the "Community" category
02-24-2024 01:24 AM
@Phil_Adelphus wrote:@mikla The plan details don't indicate that it is unlimited and from the fine print there should be a small number 2 somewhere on the plan if it was unlimited but there isn't, so doesn't look like it.
I'll be conclusive with my reponse. None of the Canada-US plans have ever included unlmited data. The two new $34 and $40 Canada-US plans are no exception.
02-23-2024 03:50 PM
02-23-2024 02:18 PM
Hi,
Does anyone know if the data is unlimited at reduced speeds after 75gb?
Thanks
02-23-2024 01:17 PM
HI @kamboski
someone confirmed with agent, it is Canada-US data
02-23-2024 01:15 PM
According to the fine print and confirmed by CSR https://productioncommunity.publicmobile.ca/t5/Get-Support/New-plan/m-p/1145153/highlight/true#M7993... data is for US and Canada.
Do a plan change at renewal to avoid loss of non-refundable plan cost and data on the current plan.
