02-18-2024 04:31 PM
I have a Public Mobile account, and am changing phones; I understand that I will need a smaller SIM card for the 6S. Does anyone have suggestions for the steps I need to take to arrange this?
Phones
02-22-2024 11:38 PM
You can even cut your sim card down to size.
02-18-2024 07:23 PM
Note that Public Mobile does not support VoLTE on that phone so you may be unable to make or receive calls in the US or Canada after 3G is shut down.
02-18-2024 04:55 PM
02-18-2024 04:51 PM
02-18-2024 04:47 PM
Hey @Roslyn_M
If you need a smaller SIM card than you have now, you can reach out to your local Telus stores and ask them. Best bet, Amazon. $4.99 there.
02-18-2024 04:38 PM
If the SIM you use now is one of the multi-size ones, you can just pop up the smaller version from it and toss the surrounding bit. Otherwise you'll have to order a new one I think.
