Transfer current member from Android SIM to iPhone 16 eSIM - No option to buy eSIM
Kev2600
How can I transfer current member from Android SIM to iPhone 16 eSIM - No option to buy eSIM in the app.
On the web browser version of PM, the button to buy an eSIM is unclickable (greyed out).
The forum has people posting the same question.
15 REPLIES 15
The thread was not marked as redundant. Repetitive content posted by anorher member was removed.
Kev2600
You move the tread as redundant but yet, no fix is available.
Kev2600
I just opened and checked and on my daughter's phone, the purchase an eSIM is not there either.
Kev2600
Here is the screenshot from the iPhone.
No eSIM options
hi @Kev2600
if you read, we asked you to use the app, not the web version
you will only see esim using PM app
Kev2600
option is not there on the iphone.
and here is the view on the web version.
@Kev2600 wrote:
The SIM was put into the new iPhone but the iPhone say it's not compatible and to call my provider to unlock it or something along those line. I have the screenshot but everyone is suggesting going to eSIM so that's why I'm trying the eSIM way.
what was the message about the lock?  it sounds like the phone was carrier locked.  Where you got it ?  You got it from some marketplace and not from Apple, right?
hi @Kev2600
my screenshot is current!!! I just check and make the screenshot moment again
try to uninstall the app, reboot your phone and try again
if not showing, ask PM support agent and hope they can tell you why the option is not there
submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
Kev2600
@Kev2600  The option is still there at least for me it’s is to buy eSIM just @hTideGnow  screen shots are missing this one step “continue with eSIM””
but honest if you already have physical sim it’s my opinion that physical sim is better to easily change devices in the fly or for trouble shooting . If it’s a matter of the physical SIM card appears to big for the new iPhone then you just have to pull the outer edge of the sim to be nano SIM card size
3 hole punch /desired size
Note flat edge corner / fit flush in tray
No lifting or rising /push in all the way
@Kev2600
@Kev2600 wrote:
You did not read the situation. I go from physical SIM to eSIM. Your screenshots are also not current as eSIM option are not in the app anymore.
Hey @Kev2600
I just opened the app. Go to the Account tab at bottom. Scroll down to Purchase SIM card, there it will tell you your phone is eSIM compatible. Continue with eSIM $5 at the bottom should be there. So ya, first one is $5 and then the next are free.
Kev2600
hi @Kev2600
Sorry, unlike physical sim card, esim cannot be transferred from phone to phone, but you can buy a Free replacement.
What you need to do is to download the PM app on the new phone, login to the app, go to Account page and choose Buy sim card and select eSIM.
the system might still charge you the $5.  Pay and install the esim first.
After the new esim is installed, submit a ticket with PM agent and for reimbursement.  You can submit ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
Chalupa_Batman
Hello @Kev2600
Download the app on the new iPhone, and you can purchase an eSIM that way. It's $5 up front but $0.00 at check out. It's super easy to do.
