Subscription did not change on renewal
Leqi_77
Hey everyone, I was tryna switch to 90 days plan on my renewal. I did select change on next renewal, but It did not switch itself. So I'm still on the 30 days plan, is there anything I can do or I just have to wait till next renewal date?
Thank you
Leqi_77
I believe they took as 30 days plan. It didn't change
HI @Leqi_77
please use Incognit/private/secret mode on your browser to login and check again.
Check if PM took the correct amount
if you were using app to check, better to logoff and re-login or even uninstall and reinstall the app and login to avoid app cache problem
@Leqi_77  Could be just a cache issue check like this and where you charged the right amount . If not use this direct link to support to investigate
Try again incognito/private mode
And or lap top /computer
                    OR
simply try refreshing the page to check data plan / mins / add ons
link to support
send a  private message   To CS_Agents click
