10-03-2023 10:59 AM
i changed my subsciption and its going to change on oct10 but ive changed my mind and would like to keep what i have but do not know how to stop the change
10-03-2023 12:41 PM
You still have 7 days to change the plan on your account. Just login and go to Add-on section and just change it.
10-03-2023 11:52 AM
did you make the change yourself or did you reply YES to a promotional offer via text?
If, for some reason, you’re unable to see the pending plan change under self-serve in your subscription area, ask the customer support agents to cancel it.
To contact a Customer Support Agent, send a private message to the Customer Support Agent by clicking here
You’ll need to be logged into your Community account for the link to work.
10-03-2023 11:02 AM - edited 10-03-2023 11:02 AM
On your profile go to subscription and add-on’s, you’ll see your upcoming schedule change below your current plan and can click to cancel it.
10-03-2023 11:02 AM
you can cancel the plan change before that date.
10-03-2023 11:01 AM
HI @Ndt6176
go back to My Account, go back to Change Subscription page and you will see the plan change schedule, you can click Cancel to cancel it
