Email
Abbi2
How do i change my email address associated to my account
@Sansan wrote:
@Abbi2  to change your email address sigin into your account and click on the Profile tab. Click on the pencil and change and press save.
The above are no longerr the correct steps.
@Abbi2
The self self serve website now requires customers to open the profile tab and then click on Manage EverSafe ID.  After doing that, you'll then need to clicks select the arrow on the right side of the email address area.
If using the Public Mobile smartphone app, you'll need to go open the Account area and then into Manage Login (Secured by EverSafe). The option to change the e-mail address is inside there.
Dunkman
@Abbi2
With the website, In your self service account, go to profile  Go to Eversafe login section.  Then you can edit email
Via the app, Go to account, then select Manage login
Sansan
@Abbi2  to change your email address sigin into your account and click on the Profile tab Manage Eversafe ID. Click on the email address or arrow  and change and press save and confirm
