Subscription Not Activated
Pogz
How can I contact customer support agent? I need to port my number to PM. Pls help. Thanks
Pogz
It's physical sim. So far just one private message from support agent then that's it. Not sure how can I transfer tonight and ready for tomorrow.
@Pogz
please use direct message
After you submit ticket, also try this on the app
  1. Click Logout on top left of the screen
  2. Wait 5 mins for the system to configure on the back end.
  3. Then log in again using the Email  and Password.
  4. The app will then  sends a code to the Email again,.  Enter the code
  5. and you will see the prompt  'Confirm for Full Access' and your Activation will be completed after
Pogz
I followed
Ask support agent  for help fist,  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
After choosing login , just blank page then "Done"at the top right corner.
When I press done it goes back to the issue.
@Pogz
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send  a  private message   To CS_Agents
hi @Pogz
if you get Subscription not activated problem, it is not a porting issue but an account setup problem
you activate esim or physical sim?
maybe just browser cache, please use Incognito/private/secret mode on your browser to login My Account to confirm again
If any issue with ticket submission, you can  submit by direct message:
