03-14-2024 09:28 PM - last edited on 03-15-2024 01:42 AM by computergeek541
Hello,
I receive a "Trouble sending. Check options" error when I try and send group text messages. I receive group texts find and can send mms and sms messages to individuals fine. I have restarted my phone and reset APNs to default but cannot fix the issue. Can anyone help?
Thanks.
03-14-2024 10:13 PM
@softech Thank you very much as that resolved my issue!
03-14-2024 09:35 PM
try to update the APN. But first delete the current APN profile . Then Add new profile and add according to this, please note case-sensivitve and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
03-14-2024 09:33 PM
Yes it is Android and my phone is Xiaomi Mi A3. MMS just stopped working about a week ago and I didn't change anything so no clue. I will try resetting all networks.
03-14-2024 09:29 PM
HI @7jz
are you on Android? what phone you have ? some older phone might not have MMS working due to the age of the phone.
But try click reset All networks , the phone will try to get a new APN and see if it works
